Agilent 7890A - Self Tightening Column Nut
Posted: Tue Jan 30, 2018 5:08 am
Hello!
Our lab purchased Self Tightening Column Nut (Inlet or Detector) due to some leak issues. We have reviewed the videos and guides on how to install it, however, for some reason the column is loose at the inlet/detector opening and slides down if it is gently pulled (even after tightening the nut). Any suggestions on why this is occurring or if this is supposed to be happening? We also installed a Self Tightening Column for the MS Interface and that one is completely secured and not loose when it is gently pulled. We are using the correct type of ferrules (listed as compatible on the installation guide) and have installed it exactly as the guide states, so I'm not exactly sure why the column is loose :S Any help is appreciated!
