I am new to this forum and would appreciate any help. I am currently working on equivalency of a method which I do not have the HS-GC autosampler model number for, only the (although it may be a TriPlus RSH or Ellutia EL2000H) based on the parameters listed). I am familiar with the Agilent G1888, 7694 and the PE 40 HS autosamplers, and none of these have the parameters listed in this method. I would like to determine the equivalent parameters on a G1888 (e.g. loop temp, transfer line temp, loop fill time, vial pressure, shaker hi/low, etc.) to the following parameters I am not familiar with:
Agitation Speed: 500 rpm
Agitation on time: 10 second
Agitation time off: 10 second
Syringe Temp: 100C
Fill speed: 1ml/sec.
Pullup Delay: 500 msec.
Inject to: GC-inj.
Injection speed: 1ml/sec.
Pre inj. delay: 0 msec.
Post inj. delay: 0 msec.
Syringe flushing: 5 min.
If anyone is familiar with these parameters and/or autosampler and could assist with understanding the equivalent G1888 parameters, I would appreciate it greatly.
Blake
