By max on Tuesday, August 3, 2004 - 01:02 pm:
Hi;
I am fairly new with a GC and need to analyse samples containing diethyl ether and ethyl acetate. I'm looking for a method using GC; however, I am still no luck. If anyone know the method or where I can find it, please kindly suggest. Thanks a lot.
By xxx on Wednesday, August 4, 2004 - 01:36 am:
to find an application for your sample
try www.restekcorp.com
www.macherey-nagel.net
www.agilent.com
There are alot of applications concering your substances....
By chromatographer1 on Wednesday, August 4, 2004 - 09:09 am:
Any OV1301 capillary column from a major supplier, Supelco Restek Agilent Quadrex SG&E Chrompack will perform the separation you desire.
the problem lies in the dissolution solvent required to dissolve your sample and handling issues-cares to perform an accurate analysis (internal standard suggested)
Good luck
