Problem is that PC sees GC but GC can't realize that it is connected to PC.
In Ethernet Setup (MS WS 6.91) GC 450 with correct IP address is available but icon does not appear.
Small icon on upper right corner on gc display shows disconnect status.
MS Saturn 220 and Combi Pal connect normally. There icons appear.
One more thing. When gc is turned on communication with MS and Combipal is broken. Message "unknown disturbance ....." appears on the bottom of Control window.
Did anyone have similar problem?
Any solution other then CPU replacement?
