Hi! I recently started to work on the Perkin Elmer Autosystem GC with split/splitless injector (CAP). The column installed is SP 2380, 100 m*0.25 mm*0.2 um. The person that has been working on this machine has limited technical training. So I decided to check the flow.
As far as I understand, this machine does not have a gauge meter for head pressure. Please correct me if I'm wrong.
Thanks!
