Hello every one. I am a novice into GC and am learning by myself. I have made an earlier post and now reposting with pictures for more ease of help. So from my research and the tests I would like to run I will need a dual FID setup. I believe I have the setup for one but I have no detectors just the remnants of the jet housings. Below will be some pictures and I will caption each of them with problems or questions I have. I just got the GC and ordered the 7673 Autosampler Tray, Injector, and the 18594A Controller for it. I also have the 35900 E Interface with a TCP/IP-LAN card. Not GPIB/RS-232. In my last post I mentioned needing a MS along with the GC and I do not. It would be nice, but dual FID is sufficient and a MS module is not in my budget.
https://imgur.com/3XrI0s0
These are all the spare parts the GC that I would Like help identifying or informing me which setup they had used.
https://imgur.com/2pidrAc
I would really like for the white piece to be identified and maybe a link on the flared brass fittings for the 1/8" copper tubing to the manifold? these ones are bigger than what I currently have on one manifold.
https://imgur.com/vJg61j2
Everything on this end looks intact for the most part. What I understand is this is a split/splitless inlet system, and that I need the detectors to connect to the top fittings on the double silver tubes (not sure what these are called, not the chemical traps to the far left) Then I will have Hydrogen gas going into the top two manifolds fueling the detectors, then I will have helium as the carrier gas on the inlet pressure manifolds. Please correct me if I am wrong on any step here. I am a real novice just trying to set this up from manuals.
https://imgur.com/gq7N5Y8
Here is the dual inlet system. it all looks intact and complete with housings and heating cores, injection ports, ect.
https://imgur.com/uQr8dC1
Here is the remnants of the dual FID setup I believe was present in the system before I won it in auction. I realize I will need a full FID kit with the housing and diode bridge for the igniters, and another ECD Board for the 2nd FID detector. If I missed anything please let me know.
https://imgur.com/csI5VW8
https://imgur.com/lKziLqJ
Here are two angles of the control board side. I know I have one ECD and need another for a dual FID setup. The ECD model on this is 19233-60015.
The model number on the Network In/Out board is 19242-60030. All the electrical harnesses look sound and intact as well.
https://imgur.com/U7woEUe
Here is a rear picture of the GC where it has no HPIB interface and my metal case shield still has the cover over it.
https://imgur.com/xJ4NkrH
here is a top picture of the network In/Out, and the Remote port area.
https://imgur.com/eyNAEtu
This is the Remote Connector.
https://imgur.com/Xj4XUYy
This is the Network In/Out Connector.
https://imgur.com/wlSQqAu
Here is the inside Of the GC. Everything besides the missing detectors looks intact too.
https://imgur.com/AoEBdZ6
Here is the rear of the 35900E Interface.
https://imgur.com/CetpZ3S
Here is a rear picture of the autosampler controller.
With all of this together I should be able to run the GC once I get the missing parts. Besides all my other questions and concerns, how do I get this hooked up to a Computer to use Chemstation? I realize this requires an older PC, but how do I do this without the GC having an HPIB interface?
