Autosystem XL gas chromatograph
Hi!
I'm trying to breath new life to our old Autosystem XL GC.
And of course I count on your help.
In particular I'm curious if anyone have a description of those DIP switches located on the right hand side of the chromatograph. Those located near RS232 and GPIB sockets.
With my best regards
Andrzej
andrzej_w wrote:
Hi!
Andrzej
While it isn't direct help, Perkin Elmer should be able to provide you with the manual to the instrument if you email them. I had to do this for the same system at my previous institution and for a PE 200 HPLC we were donated. I no longer have access to either or I'd send it your way.
hi andrzej, i have the same question, did you find out about the dip switches ? (i mailed PE maybe in august or september 2022, still waiting a reply)
and excuse my curiosity, but what software are you using with your PE XL ?
https://resources.perkinelmer.com/corpo ... anager.pdf
Check p. 180.
Mine is set to DIP switch 6 = on for RS232. The rest of the communication can take place through USB-RS232 adapter.
For software, I'm using TotalChrom 6.3.3, but Thermo Chromeleon 7.3 works too.
thanks a lot, pdf is about Link600 interface device, but seems to match with the Autosystem XL dip switches
i would like to create a RS232 driver for Unichrom, so i'm desperately looking for the PE command list, any clue ?
Users browsing this forum: benhutcherson and 1 guest
