Recently we started working on the new Perkin Elmer gas chromatograph Clarus 590, after setting all sequence and calibration methods and getting very nice results from control trials - a problem began in production trials.
I study hexane isomers on it with the internal standard which is n-heptane. The highest peak that integrates is 30ppm - everything below is inintegrable for device. I used the option in the graphic editor to choose the necessary parameters himself, but it did not help.
Could you help me with that? :)
