n-heptane as an exchange solvent for hexane
Posted: Mon Jan 29, 2018 11:49 pm
by LALman
Has anyone tried using n-heptane as a final solvent when blowing down hexane to lower volume. Also, who prefers n-heptane for GC-FID DRO analysis and why?
Re: n-heptane as an exchange solvent for hexane
Posted: Thu Feb 01, 2018 3:53 pm
by Multidimensional
Perhaps you are not aware of the fact that these two different solvents have very different vapor pressures and boiling points? n-Hexane's bp ~ 69C and n-Heptane is close to water at 98C. Using heptane to dry something down would be a step in the wrong direction.
Link to "HPLC Solvent Properties Table (e.g. Polarity, Density, Boiling Point...)"; https://hplctips.blogspot.com/2011/11/h ... table.html
Posted: Fri Feb 09, 2018 10:14 pm
by LALman
Yes, I am aware. I was thinking that if one dried down at modest temperature 40-50C. Then you could add 1-2 mL of n-heptane to larger volume of (n-hexane and DRO) mixture for example. Blowing that down would effectively transfer the DRO into 1-2 mL of n-heptane. That in turn can be dried and transfered to capped vial for analysis.
Posted: Sat Feb 10, 2018 12:35 pm
by Peter Apps
The point of this escapes me completely. The only effect would be to delay the evaporation to dryness. If you are evaporating to a fixed end volume the heptane does no good, and still slows things down.
Posted: Mon Feb 12, 2018 12:46 am
by LALman
I thought perhaps I could avoid accidentally having my whole sample evaporate to dryness while I was attending to other things in the lab. I thought maybe evaporation would slow greatly as the volume approached that 1mL of solvent that had twice the B.P..
Posted: Mon Feb 12, 2018 8:18 am
by Peter Apps
It would, but it was not clear whether you wanted to evaporate to dryness, or to a fixed volume.
Posted: Thu Feb 15, 2018 5:28 pm
by James_Ball
Similar to the Drinking water method that uses Ethyl Acetate as the final solvent. The DCM will evaporate quickly and the EtOAc takes a long time to come to final volume of 1ml at 40C-45C.
As long as the Heptane peak will separate well from the lightest component of the DRO then it should work well, and you don't have to worry so much about a vial concentrating if it sits on the instrument overnight after the septa is punctured.
