first of all I'm not sure whether this is the right category of the forum. But I think topic "Sample Prep" comes most close to my problem.
We are using the AI 1310 autosampler (ThermoScientific) with the rack for eight samples. Vials are 2 ml ones with crimp top. We are closing the vials with a manual crimper.
The problem is that sometimes the autosampler is dislodging the vial from the autosampler and throws it out. This is quite inconvenient as this happens usually while the syringe is washed with the sample and when the autosampler draws the actual sample there is no vial present anymore.
Has anyone experienced this as well?
Thank you very much for any tips or hints!
Janosch
