I'm wandering if it is necessary that the sample has to be completely dissolved in the solvent you've chosen to carry out the analyses of trace solvents/impurities.
Specifically, I'd like to know quantify and analyze an analyte that is part of solvate with the API I'm interested. This API is not soluble in the solvent (water) I've chosen to perform the analyses, and i wouldknow if i will be still able to see the analyte though the API is not soluble in water.
thank you
