We have recently got a second hand Dionex P580 HPG HPLC pump and have a few problems in getting it to work. As soon as I try to start the pump it gives me an error message " Internal leak sensor detected leak". There really is not a leak in the system. I have cleaned the leak sensors (both the plate underneath and two inside the pump) and tried to start the pump while they have been disconnected with no luck.
Any ideas on how to get it up and running?
