Issues with Perkin Elmer 200 Series Pump and Chromeleon
Posted: Thu Nov 15, 2018 1:41 pm
Hi everyone,
We have an existing Perkin Elmer 200 series HPLC system (binary pump, UV/vis detector) that runs happily with Chromeleon.
We recently tried to set up another system that has the Perkin Elmer 200 Series UV/Vis Detector and a Perkin Elmer 200 Series Quaternary Pump. The UV detector can be controlled through Chromeleon no problem. However, the pump will be happy for about 1 - 2 min (can change flow rate, solvent composition etc with Chromeleon) but then I get the following errors:
1) The communication FIFO "Audit7_LC200 Pimp" of the DDk driver "LC200 Pump" is corrupted.
2) The communication FIFO "Reply7_LC200 Pimp" of the DDk driver "LC200 Pump" is corrupted.
3) Driver LC200 Pump (PELC200Pump.dll) has terminated. This is a fatal error, you need to restart the instrument Controller to recover.
Any ideas?
Any ideas?
