mlhuls01 wrote:
What are the pros/cons of screw vs crimp caps?
What benefit do you see from either?
With electronic tools that crimp and decap for you I wonder who would want to screw all those lids on by hand? Are there benefits I don't know about?
One thing I have noticed with screw caps is that if you use the kind without a pre-cut septum and you tighten the screw cap too tightly, I've seen inconsistent sample injections and I have even seen the auto-sampler needle on our GC actually pick the vial up from the tray because the needle didn't come out properly.
I prefer screw cap, personally just because I'm filling every vial up with a different solution and I can just cap it as I go.
I have found the crimp cap better with an automatic crimper when I'm filling up 50+ vials of the SAME solution and I go through and pipette X amount of volume of the same solution into 50 different vials. Then I can just go in and crimp them all quickly with an automatic crimper.
I think the bigger concern I've always had was how tight I make the screw cap and whether or not the cap came with a pre-cut septum or not.
