we are looking for a degasser with as small an internal volume as possible. Since we are using it for the inlets to a nano/cap LC pump, solvent will flow very slowly and we are worried about changes in composition if it stays in the degasser for too long (even though it should not really be a big problem with our solvent composition).
The smallest ones I've found up to now are the DEGASi micro from http://www.biotech.se/ (100 uL) and the Capillary channel by IDEX (also 100 uL) http://www.idex-hs.com/products/4260/MI ... FamilyID=6 which would have to be used in a IDEX degasser, presumably. (I suspect that these might even be the same products...)
Any other ideas or experience?
