This is related to my separation using C18 trap column in combination with a HILIC column.
For some separations, the 20 µl of RP-solvent in the C18 trap column (2.1x10 mm, XTerra C18) is too much for the HILIC separation.
Do you know if there are shorter C18 precolumns on the market? I have not been able to find it on Waters or Thermo's homepages.
