when I inject a sequence (3 * standard, 2 * samples) I must always check the following system (resolution, theoretical plates) of the first injection of the standard, before it begins to inject the samples.
I would like to know how to put a condition in the first of the standard, for example the resolution is <2, or the trays <5000 == stop of the sequence.
it will help me a lot to avoid investigations. thanks in advance
