I’m currently working on TPH quantification (C10–C40 range) using GC-FID with Shimadzu LabSolutions, and I’m running into an integration issue that I hope someone here has solved before.
For each TPH fraction, I need to integrate a fixed retention-time window (for example 3.00–3.50 min) rather than individual peaks. The problem is that LabSolutions keeps giving me messages like “peak not detected”, and then refuses to integrate the area for that time window.
I’ve already tried adjusting several integration parameters such as minimum area, threshold, peak width, etc., but the software still aborts integration whenever it doesn’t detect a clear peak in that region. What I need is very simple: force LabSolutions to integrate the signal between two retention times — even if no peak is detected.
So far I haven’t found a setting that tells LabSolutions to “integrate this interval no matter what”.
Has anyone dealt with this issue or knows if there’s a specific option in LabSolutions to enable forced time-window integration?
Any tips, hidden settings, or workflow suggestions would be greatly appreciated.
Thanks in advance!
