Clarus 590 FID
The spring-loaded pin that extends from the collector assembly broke off. Perkin Elmer says I need a whole new assembly but I wonder if anyone else has figured out a way to repair one of these.
Secondarily... I took the thing apart and a little spring popped loose (not the one pushing on the pin I mentioned). I'm not sure where it came from. Any ideas?
I've never repaired one. I believe the Autosystem/500 collector is the same and we have several of those lying around.
No way to fix that broken pin that I know about. BTW, the spare part (N6550077) is specific for Clarus x90, and not compatible with the x00/x80 series.
There are two more spring-loaded pins inside the collector assy: One makes the connection between the polarizer side arm and your broken pin; the other connects the signal output (BNC connector) to the central (hollow) electrode.
keep trying to respond but getting blocked as spam. I did confirm they changed the collector and unfortunately the old FID doesn't fit the newer lower jet assembly.
very good and useful article if we use omegle tool
Most users ever online was 4374 on Fri Oct 03, 2025 12:41 am
