Yes, it is possible to do that, my previous company has the same policy before. Instead of using the label reference directly . we input the same sample with the same lot#. see below for detail
U0101 & U0102 are from Lot# A0001.
Difference% from U0101 from Average of U0101 and U0102 can be calculated. and Diff% is double of difference%
U0201 & U0202 are from Lot# A0002
U0301 & U0302 are from Lot# A0003
and when the lot# is the same. calculate the average of the assay% for the same lot# and individual amount will have same difference% with average and double the difference% as diff% you need, where you can get the diff% for the pair samples.
George
Hello everyone,
I'm currently working on Empower (Waters), and I'm trying to create a Custom Field that calculates the percentage difference between two samples within a pair, based on the Amount field.
Here is how my samples are structured:
U0101 and U0102
U0201 and U0202
U0301 and U0302
... and so on.
I've done some testing, but I can't get it to work. I'm not sure how to configure Empower to apply the %Diff calculation to each pair of samples (e.g., U0101 and U0102), then continue with the next pair, and so forth.
Can anybody please help me ? Thank you very much
