HPLC Column Query
Hi guys
I am currently in the first year of my PhD and trying to set up an HPLC method for the analysis of phosphonate scale inhibitors. The method was previously developed a few years ago by a member of staff who is no longer here and although the method works ok I am a bit confused as to why the column used was chosen.
The method uses a Dionex AS11-HC column which is designed for the analysis of anions, however I am analysing scale inhibitors. Does this seem odd to anyone? Why would such a column be chosen?
Any advice would be appreciated :)
That's not that strange as phosphonates are organic acids based on phosphonic acid See http://en.wikipedia.org/wiki/Phosphonate.
Dr. Markus Laeubli
Manager Marketing Support IC
(retired)
Metrohm AG
9101 Herisau
Switzerland
It seems perfectly reasonable to me. That column is good for measuring phosphonates. You are looking for things
that inhibit phosponates so look for the least amount of phosphonates produced.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
