Edit: GCsolutions v2,30 SU6, running WinXP Pro.
GJMS
I know... its the DOA install. I did it from the start and it didn't work.Tarapan wrote:
Check the installation cd again. theres another program your suppose to install before installing the GCsolution software. I cant recall what its called need to check at our lab computer wat that software was.
menno wrote:
I have solved the problem by copying the gc config files (system/gcsystemconfigx.cfg) from the computer connected to the GC to the (offline) workstations in the same directory (gcsolutions/system) and overwriting the original. open the real time once and close again. afterwards postrun was working.
AngelicaV wrote:
Hello everyone! I thought to add my question in this post instead of creating a new one.
Anyway, I'm pretty new to GC Solutions - have worked mainly with Empower in the past. What I don't quite understand is integrating peaks with GC Solutions. Everytime I make a change in the integration, I have to save the method, start from the beginning, and load the method to each individual run. It's extremely tedious but it doesn't seem like anyone else is aware of any other way to work with the software.
Now with Empower, you can change the integration in the processing method, and all the other runs will reflect that change. All that's left to do is review the data in the sample set, perhaps make a few minor changes, and process.
GC Solutions: Save, click on run, load method, save method, click on next run, load method again, save method again, click on next run, etc. Then when you review your runs, you find you need to make a minor change somwhere... do it all over again.
There has to be a better way. What am I missing here??
