by
DR » Tue Oct 25, 2016 12:44 pm
I did not think that would work
Creating, archiving and restoring a project on other workstations should work.
The trick is to limit what goes into this new "sneakernet" project. Only the report method and any associated custom fields should go into the new project from the existing project (you will not be archiving the existing project or any of its data). Just drag them (report method & needed custom fields) into the new project from the existing project and do not take any data (no sample sets or results sets) into the new project.
When you make the new project, make sure that the full audit trail status (FAT) matches that of the project from which you intend to copy the report method.
This way, there is no worry about data security. Once the "sneakernet" project has been restored onto other workstations, its report method and any associated custom fields can be copied into other projects (that have the same FAT status).
