I'm a LIMS developer trying to diagnose an issue with MSD Chemstation. I'm not totally up to speed with the science & terminology behind GC-MS and the lab technicians aren't experts in MSD Chemstation - they just know the bits they need to do the job. Normally between us we can work through issues, but this time we're asking for help!
We’re using MSD Chemstation on Windows XP and Windows 7. The versions in use vary by instrument (we have 7 GC-MS instruments): The lab technicians tell me the following versions are in use:
D.0200.275
D.01.02.16
E.02.01.1177
E.02.02.1431
The instruments are integrated with a LIMS system (Labware LIMS v6) – this has been done by editing the “deuser.mac” file of each method to call a separate macro to copy the result files to network folders.
We are experiencing an issue with our “Drugs Search” method. This is a qualitative method to determine if any controlled substances are in the sample. Sometimes the “deuser.mac” doesn’t seem to execute and therefore the results don’t get into the LIMS system. We have narrowed this down to the following situations:
• When a BLANK sample is run (and no drugs are found in it)
• When a normal, analytical SAMPLE is run (and no drugs are found).
In both cases, an error is displayed in the status bar:
“An error occurred in quantitation reporting : Compound not found in quantitation database”
Now, obviously if no compounds are found then there is nothing to search for, quant wise. But the main question is: Why is it attempting this at all? The method is not supposed to be doing any form of quant (we have other methods for that). On samples (or blanks) when drugs are detected, this error doesn't occur. But no "quant.txt" file is created either - which correct for this method, but doesn't quite fit with the error message!
How can we stop MSD Chemstation from trying to quant a compound when none have been found?
Andy
