Our lab has a 5977 doing purge and trap VOA analyses and for about a year it ran great, tunes held for a long time, chromatography was good, baselines were good. Now there's so much noise in the baseline it's difficult to reach necessary detection limits.
About two years ago it was taken apart for "routine" maintenance, source cleaned, filaments changed. It's never recovered from that day, and I'm trying to figure out what happened. I've cleaned the source a couple times now, changed filaments.
I just discovered something very strange. The transfer line looked bent. Like, really out of place, but it seemed to enter the transfer line socket on the source body ok. I took the whole transfer line assembly apart and it turns out the housing that holds the 2mm transfer line was the bent part. Looks like a manufacturing defect because the bend happened at a spot where two parts were welded. I can't determine if this has anything to do with the problems we're having.
I just rebuilt it and ramped lenses to see how everything looked. I CANNOT get any ions to maximize when ramping the repeller.
I changed the insulators and the repeller. Still, I cannot get 69, 219, or 502 to maximize anywhere along the ramp. I have no idea what to make of this.
Christian
