Here's where things start to go awry. When I run blanks I notice that the baseline, which is acceptable in the DAD drifts and is generally awful in the RID. I do see a solvent front in both the DAD and the RID. When I run our products, malonate, the sensitivity is far higher than in the RID. I ran a curve of concentrations from 10µg/g -> 100µg and all I saw in the RID was noise.
I am not as familiar with the RID as the DAD. I do have the heater set to 30ºC. What other places should I look to help with the RID?
